TwinTurbo.NET: Nissan 300ZX forum - Also check the 10 amp "theft control" fuse.
ttz'in (NorCal)
on August 10, 2014 at 2:04 AM
Re: Re: From prior post, did you disconnect that new
posted by ttz'in (NorCal)
on August 10, 2014 at 01:50 AM
Lower row on the end, sticks out a little more than the others.
keep burning up time control units in the same exact spot wt
3hundaZ
12:22:07 08/09/14
ttz'in (NorCal)
14:20:43 08/09/14
3hundaZ
17:51:30 08/09/14
ttz'in (NorCal)
01:50:39 08/10/14
Also check the 10 amp "theft control" fuse. -
ttz'in (NorCal)
02:04:43 08/10/14
And a very useful link....
ttz'in (NorCal)
02:51:12 08/10/14
Re: Re: Re: From prior post, did you disconnect that new
3hundaZ
16:16:22 08/10/14
Do you have a test light or multi meter ? (n/m)
ttz'in (NorCal)
16:27:43 08/10/14
Re: Do you have a test light or multi meter ?
3hundaZ
23:38:54 08/11/14
Great, click on link and open to electrical section.
ttz'in (NorCal)
02:04:54 08/13/14
Are you using the correct size fuses?
ThisIsSparTTa
17:30:21 08/09/14
Re: Are you using the correct size fuses?
3hundaZ
17:49:41 08/09/14
